03-02-2022, 03:26 PM
The BECG has been given a number of these 12" video monitors. 15 came from a BBC site, about 30 from elsewhere, though these were also ultimately ex-BBC. I've written previously about converting them to 405. This is about making sure that they are good for service as ordinary 625 monitors in our ABC-Thames truck. It will need about 18 of them in total.
https://becg.org.uk/projects/abc-thames/
I've had the 15 that came directly from the BBC sitting at home for for over 6 months, looking at me reproachfully for neglecting them. Late last year I gave them all a cleanup and removed laods of labels. I also powered all of them for a first assessment. I finally got back to them a few days ago. Here are a few on soak test on my bench.
They were in pretty good nick. All the CRTs woke up nicely after an hour so running. On each one I replaced a capacitor (110V rail reservoir) that leads a hard life and has been known to fail. I also bridged out the internal/external sync switch which is nearly always intermittent. A squirt of Servisol in all the presets, general tweak, and most were good to go. One had a blown 2N3055 series pass transistor in the main power supply. Still worked but with bad hum and everything a bit stressed. Another had intermittent contact on a connector to the field scan coils.
The worst offender worked nicely much of time but failed the smoke test sometimes. Eventually I caught it in the act. An intermittent connection to the line scan coils. I ground away the burned bit of the PCB, which was only obvious from the underside of the board. There's a lot of power circulating in a line scan circuit, sveral hundred watts, but almost all of it is recovered by the efficiency diode. When it gets loose, such as via a bad contact, it can do real damage.
They are all now good working monitors, ready to go up to our new base at Hemswell Cliff, the building that will become the Broadcast Enginering Museum. See photo of front of main block as we bought it last year. It's looking better now but still a long way from being ready.
