17-06-2021, 08:46 AM
Not sure if this should be in this forum or the wanted section so sorry if I picked the wrong one.
I have a Ferguson 991T that I have worked on to the best of my abilities it was my first attempt at a TV to get working, and modern components have been used rather than re-stuffing old caps etc. I recently fitted a better MW36-24 to the set and that has improved things to good effect, but I still have issues with the set such as echo's on vertical lines, this to me does not help focus etc.
It was suggested that the set have been tuned at some time for better signal rather than bandwidth and even though I have tried my best to tune the IF back according to the manual, the vertical lines are still there, so I suspect some ringing. I had a few replacement vales fitted during my work on it such as the EHT section and a few others. It works reasonably enough to view, it still has a few niggles and I believe it could be better.
So I am wondering if I can ask for the services of anyone with more knowledge/familiarity with TV's to look over it. I will have to consider transporting it from the Blackburn area to where one may be and collecting again it some point later, so the distance could become an issue.
Costs covered etc, I am not asking for freebies. So if anyone has the time and inclination please contact me via pm, or on this thread.
Cheers
Adrian
Cheers
Adrian
Learning as I go!
Youtube EF91 Valve
Youtube EF91 Valve
