13-08-2020, 09:31 AM
In October 1939 RCA tested television reception 4 miles up and 200 miles down range from the New York transmitter.
Peter
Peter
TRK12 in Flight
Peter
13-08-2020, 09:44 AM
I wonder how well the signal was received?
There may have been a lot of aircraft flutter
13-08-2020, 09:51 AM
It could have been a flying spot scanner instead of a TV.
![]() Al
Tuned for maximum smoke .
13-08-2020, 10:51 AM
The receiver has the look of an HMV 900 about it, but that would have been a common technology at the time. I'm sure pictures were received, but quality is another matter. We don't know.
PS: If you do weaving in an aircraft, will the loom use a flying shuttle?
If it was as heavy as a 702 that plane did well to get off the ground!
Any info about the receiving aerial? Steve
13-08-2020, 10:52 AM
A 702 or 900 may be a heavy brute, but no worse than a couple of passengers.
13-08-2020, 10:58 AM
I can assure you that RCA didn't use an HMV900 or any other EMI set. It was a TRK12 and weighed 198lb. http://www.myvintagetv.com/Apple%20PDF%2...Manual.pdf
Peter
13-08-2020, 11:21 AM
I'm sure RCA used their own set, but it has the look of an EMI mirror lid. Nicely lethal 7.5kV mains EHT
![]() I was being generous with the weight. There are plenty of people (not you or me) who weigh more than 198lb. Just over 14 stone.
(13-08-2020, 10:52 AM)ppppenguin Wrote: A 702 or 900 may be a heavy brute, but no worse than a couple of passengers.Err.. that had been my attempt at a weak joke. Or just one passenger in the case of 'yours truly'. Steve
13-08-2020, 11:27 AM
Steve, no worse than some other jokes in the thread
