12-10-2018, 04:09 PM
Many years ago I removed the push about coil from my HMV901 because it appeared to distort the edge focus and I didn't really need it to get my picture centred.
More recently I decided to try it again and once again decided to remove it but removing it didn't get me back to the edge focus I had previously and my scan now had some trapezoidal distortion. Checking the push about coil I found that its iron core had some retained magnetism and I wondered whether the CRT cage and the iron core of the scan coils also had retained magnetism. Just today I tried using a degaussing coil around the CRT area and have been able to largely remove the scan distortion and also improved the edge focus.
If you have one of these early EMI sets fitted with a push about coil I would highly recommend removing it and degaussing the CRT cage and scan coils. You my need to make other arrangements to hold the scan coils up close to the cone of the CRT.
Peter
Peter
