21-05-2017, 07:20 PM
Hi.
I'm in the process of building my second Mullard 3-3 Stereo amp on an economy basis.
I have now made four of these amps in the last couple of years and each of them brings a smile to may face with their performance and quality.
My latest is for my own use and is built on an old chassis retrieved from a Codar CR66 that was missing it's case and coil pack.
It's actually built back to front and I wasn't sure if I'd land up with hum or feedback. After completing one channel all I can say is I'm impressed
In this version I'm using an EZ81, fed from a 350-0-350v winding for more head room and resistor and choke smoothing. The anodes of the EZ are fed via 100R 5W5 (10watt) gold resistors the cathode for one channel via a 350R (R15) resistor to 100uf, choke and 47uf (C9) smoothing, the cathode resistor will be reduced once the second channel is complete.
On the stereo version we don't need R12 & C6 in both amps as they can be fed from one pair, R12 should be dropped in value and I find 2.7K 2 watt is fine, no audio ripple can be detected on C6.
The circuit shown above is the one less the bass and treble controls, mine has the controls fitted.
Now the layout I'm using is totally different to Mullard's but I have no detectable hum and the use of quality modern components also means there is no detectable noise.
Once I've completed the job I'll post up the underside layout and do a video of its performance.
