When I moved here in 1998 I overhauled the central heating system. Actually almost a new installation. All that was left of the old was the boiler (since replaced in 2011) 3 radiators (out of 14) and a few pipe runs. I used Drayton TRV4 thermostatic valves as they are meant to be the best available. https://www.screwfix.com/p/drayton-trv4-...mm-x/26100 They're not cheap, £30 now, though rather less back then.
I've just had the 3rd valve body failure. I've also had 3 or 4 heads fail, with crumbling plastic. I can't say I'm happy. When the last valve body failed I decided that £30 was a bit rich so I decided to use a Peglers valve:
https://www.screwfix.com/p/terrier-3-whi...tid=225690
I've used quite a few Peglers products and the quality has always been first class. That TRV is only about a year old so too soon to say about reliabilty but it feels better made than the Drayton. Smoother action, not so prone to making odd noises when almost closed. Pegler do a more expensive TRV with liquid thermostat element but the wax one seems fine.
I've ordered another Peglers valve to collect tomorrow morning. Then the usual faff of turning off lots of other rads, depressurising the system, replacing the valve, repressurising, rads back on. I turn off other rads to minimise loss of treated water.
I suspect this won't be the last time I do this. I could replace all the Draytons as a precaution but that's a fair bit of money and effort. So it will be one at a time and cursing on each occasion.
