07-09-2020, 05:33 PM
Car battery packs are now often reckoned to last the life of the car. In very rough terms 250 miles per charge and 1000 charges give you 250,000 miles. Old car battery packs are re-purposed as domestic batteries, to work with PV. The reduced capacity is less important and the operating conditions are kinder, with less temperature fluctuation and lower charge/discharge currents.
The currents in an electric car traction system are quite scary. If the battery is 400V and you have a peak 200kW output that's 500A. OK, 200kW is about 270hp, a fairly powerful car, but it's not outlandish. You really don't want to get yourself or anything metallic across the battery.
It's rare and desirable
