20-04-2013, 02:36 PM
I'm wondering if that circuit should (under normal conditions) self oscillate with the 12AU7 pulled, the phasing of the primary windings would seem to indicate so? It might help to narrow things down? The downside is that if the 12AU7 s pulled and it does oscillate then there will be no control over the EHT by RV500 (if that's what it normally does)
And, perhaps more to the point, where is the -150 v. at the grid of the RH 12AU7 coming from?
