Not sure how to quote more than one person in just one post. Anyway:
Peter wrote: Did I calculate correctly in suggesting the scanning disc curvature would be less than 3 line widths for the 240 line picture?
Maybe for a full 240-hole disk, but for a 60-hole one (allowing through more light and a larger frame) I make the curvature to be over 8 lines. See attached. Check any 'maths' from me carefully. It's often wrong. Do you know the actual hole count and size of the 'film' disk?
Mark wrote: Was your ZIP file was within the size limit? If not, could you try a smaller one, just to be sure there's nothing wrong with the settings for your account.
My file was OK for size then. If you see it here, then my second try has succeeded. Thanks by the way for looking into this.
Jeffrey wrote: Steve, I remember that production only too well. I don't know how much of your advice they took.
You're being diplomatic.
Virtually zilch i should think.
Steve
Virtually zilch i should think.Steve
