14-11-2014, 09:39 AM
The transformer I have is a 'proper' iron & copper device, Peter. It's designed to power 110/120vac equipment from 230/240vac, and, being rated at 45W, will be more than adequate to operate the SLB20D, which only requires 2.5W @ 110v. I'm not sure, but can easily check, whether it's double wound, or an autotransformer, but it is totally insulated, the U.S. socket being built into the plastic case, which incorporates a 13A plug, so no extra trailing wires are involved, just a rather heavy 'wall-wart' type device to plug into a mains socket
