11-11-2014, 10:48 PM
This turntable uses a DC motor with electronic speed regulator circuits, and is a N. American market model, made (obviously) for 110-120vac @ 60Hz, but, having powered it via a MW2P045 230/240vac to 110vac Transformer, and played a familiar LP on it, which, to my ears, runs at the correct speed, as I'd expect it to, because of the DC motor, would there be any problems caused by long-term use of this T/T and inverter? (The latter is rated 45watts, or, more correctly I guess 45VA, @ 110v, which is more than adequate for the turntable) There is no pitch control on the SLBD20D, although there may well be internal pre-set(s) for accurately setting the speed if need be. This appears to be much the same as the UK market SLBD22D, for which I have the service data.
