19-02-2025, 12:03 PM
We've recently been given a GPS locked SPG, along with antenna etc. Ideal for our purposes. If GPS fails there will be many with greater problems than us. Our SPGs with crystal ovens aren't bad timekeepers. I think we're better than 2 parts in 10E7, or at least we should be to meet the PAL spec which is 1Hz in 4.43MHz. A year is about 3E7 seconds so that's a few seconds per year.
The modern way to lock SPGs is PTP over the internet.
When I first designed SPGs, you could only get the PAL spec with an oven which is expensive and slow to warm up. Albeit a pretty low grade oven. I used TCXOs in later designs when their digital compensation meant they could achieve the spec at lower cost in a smaller package.
