16-02-2024, 09:45 AM
(This post was last modified: 16-02-2024, 09:48 AM by ppppenguin.)
Golborne isn't doing agriculture
This COW is the BBC's Computer Originated World. There quite a lot about it online, inlcuding a wikipedia page and several interesting links from there. https://en.wikipedia.org/wiki/Computer_Originated_World
The COW at the Broadcast Engineering Museum was used by BBC World. This COW was unwell, with intermittent problems as the globe rotated. I took it home with me to put on the bench. It weighs over 30kg and is a 9U (15.75") high rackmount unit.
The COW has about 300x 27128 EPROMs that contain runlength encoded data for the rotating globe plus another 112 EPROMs for the fixed data. There are 14 memory cards, each of which holds up to 32 EPROMs.
I don't have an extender board so it's tricky to work on the cards. Swapping sets of up to 32 EPROMs between cards was a horrible job, reduced to merely tedious when I found a pin straightener.
I won't go into details of the faultfinding (unless you insist) but both faults were failures in sections of 74LS377 chips. https://www.ti.com/lit/ds/symlink/sn74ls377.pdf The '377 is an 8 bit D-type register, less well known than the '374. The great thing about the '377 is that is has a clock enable and so can be used for proper synchronous logic design.
In one case I was able to swap an offending memory card to a slot where that chip wasn't needed. In the other, I cut tracks and used wire links to swap the offending section with another, unused section, on the same chip.
The COW has been on soak test for several hours and is mooing contentedly.
I should add that I have previously overhauled the COW at the Dulwich museum. That didn't have any awkward digital faults, just a horrible bodge in the digital to analogue converter.
If anyone has a few 74LS377 to spare they would be much appreciated. I have a 74ACT377 in my store but AC and ACT series are a bit fast and hairy when there isn't a ground plane and really good decoupling.
This COW is the BBC's Computer Originated World. There quite a lot about it online, inlcuding a wikipedia page and several interesting links from there. https://en.wikipedia.org/wiki/Computer_Originated_WorldThe COW at the Broadcast Engineering Museum was used by BBC World. This COW was unwell, with intermittent problems as the globe rotated. I took it home with me to put on the bench. It weighs over 30kg and is a 9U (15.75") high rackmount unit.
