07-01-2025, 04:32 PM
Hello all, and happy new year.
To take my mind off certain medical issues I've started to try to restore my first television, which is an Ultra V1770. I'm lacking experience and struggling somewhat. I appreciate that this set is not especially well thought of, but it's what I've got.
First step was to sort out the reservoir and smoothing caps, followed by waxies in the line and frame stages. I'm hoping to get a raster before moving on to the I/F and tuner.
The frame oscillator valve was missing and I've replaced it with a NOS one. The frame oscillator seems to be running OK albeit somewhat fast. 50Hz and below are only achievable by turning the frame hold control nearly to minimum.
The line oscillator runs, but a fair bit too fast. The line hold control operates, but the minimum stable frequency is about 6.7kHz. Any lower than this and it becomes unstable. I'm not currently (no pun intended) getting any EHT. I did for a couple of minutes, at which point even my hearing was able to detect a line whistle. My homemade ring tester suggested that the LOPT is OK. The filament of the EHT rectifier is OK.
What should I check next? Any help would be appreciated. I have a scope and diff probe which is good up to 750V, and all three service manuals (manufacturers, Trader and Radio Retailing)
My name is Steve, but I answer to most things like "Oi, you!".
