10-09-2024, 06:50 PM
We have a 3.5 year old Beko built in automatic washer.
For several weeks it started to smell after use, despite leaving door open and running a wash with a dishwasher tablet only.
Last time we did this, I touched the glass door and it was cold, when it should have been hot.
Quick google suggested the element had gone and was a fairly common fault it seems.
Even a video showing how easy to change.
So, after withdrawing it from under the worktop ancd confirming the element was o/c, I ordered one from espares ( part of screwfix) at £19.95 + £6.95 next day delivery.
Upon arrival, it had the same markings as the original one but a 2024 year stamp.
It had arrived this morning and due to an innovative design involving one nut to push or pull the element towards the sealing gasket, it was replaced in a few minutes.
Most time was spent removing the washer from the very tight space under the worktop and replacing exactly where doors would line up.
It has been a reliable washer, straightforward to operate, smooth and quiet in operation, even at 1200rpm spin.
Looking around, even the pump looks like a few minutes to replace.
The online video (espares) showed the same element, but in a Bosch machine. That needed a lot of dismantling to do the replacement and cost maybe £100+ more when new!
I feel that this easy replacement and online availability of parts is a very positive step in maybe saving appliances that would otherwise be scrapped.
I realise that the same job carried out by a company could probably be £100-150 plus when callout, travelling, engineers time removing from fitted unit and vat is taken into account.
Rob
Rob
) and try to just have a standard white door model.
