17-03-2023, 11:30 PM
(This post was last modified: 17-03-2023, 11:31 PM by gary_crutchley.)
Hi all,
I have a Cossor 494AC that I partially recapped a few years ago and use regularly. Recently I noticed a pronounced hum, inspection of the base of what is the original reservoir/smoothing capacitor confirmed a sizeable bulge and small crack in the rubber seal. The can was also leaking a small amount of electrolyte through the cracked base.
I have replacement capacitors on order and plan to fit them under the chassis rather than restuff the original can. I have replaced standard capacitors previously, but this is my first attempt at electrolytics so any tips and advice would be gratefully received.
Thanks in advance and best regards,
Gary
