26-02-2023, 06:45 PM
I have a Philips L2G32T that is a little bit distorted and is drawing a very low current, 6ma. According to the manufacturers sheet and the radio servicing sheet they both state the quiescent current drawn by the radio should be about 15ma. Output bias resistors have been checked, the base bias resistors were replaced as they were well out of tolerance and after 1 or 2 electrolytics were replaced it’s no different. DC voltages on all of the transistors in the radio are very good, another speaker has been tried in case I had a bad speaker. I eventually removed the output transistors as I thought I might have had one that was not good, they were tested on a Chinese tester and they were found to be low gain but not overly low. According to my Towers book minimum hfe for the OC81 is 50, my transistors have a hfe of 40 and 37 respectively, would this give me my symptoms??
I don’t have an oscilloscope.
Danndad
Danndad
