I am putting this in this section as I am planning something for the future but the circuit I am basing things on has me stumped.
This will be for a modulator, the plan was to use part of the circuit as used in an old military radio as I have the mod driver transformer out of it, unfortunately the interstage transformer was toast.
Anyway here is the circuit from the available online manual.
The area that has me baffled is 2V2, the HT is 250 Volts, The cathode bias resistor is made up of a 1K2 and a 2K7 to give 3K9 total, with the grid bias taken off at the junction of the two resistors via a 330K resistor.
In a later section of the manual it lists the voltage on the Cathode of 2V2 as being 10.5 Volts.
So this would put the grid bias at -3.2 Volts with respect to the cathode? The valve is a CV136 or EL91 and OK with 240 Volts across the valve rather than 250 I would not expect to see much difference in Ic but according to the spec sheets at -3.2 grid bias, 250 Volts on screen and anode, the anode current Ia should be around 55mA and not the 2.7 mA suggested by a cathode voltage of 10.5.
Considering the screen current Ig2 should be around 2.3 mA, then there is only 0.4mA of Anode current in the manual?
Now the manual also states using a meter with 1,000 Ohms per Volt and I am guessing a 25 or 30 Volt range to take the measurement, so the true Cathode Voltage may be around 12 Volts with -3.5 Volts Grid bias but the spec sheet for the valve would still put that at 50mA anode current.
I can not build the circuit as the transformer 2T2 is duff. But even with a 1K resistor in there I could not get the values to work out.
So I am confused as to what I have wrong, or, if the manual is wrong, if I have neglected something like space charge across the 330K resistor adding some more negative bias.
So please assist if you can and say what I have wrong/missed etc.
Adrian
Adrian
Learning as I go!
Youtube EF91 Valve
Youtube EF91 Valve
