30-08-2022, 06:25 PM
I have an ekco zodiac u800 here that I cannot get the grid 2 voltage to be lower than the anode voltage as stated by the ekco sheet. The voltage instructions state that they should be taken with mains input @210vac into the 200-220 volts tap with the anode on the ul84 at 144v and grid 2 at 142v, those conditions can’t be met here with mains voltage at around 240vac at present.
With mains voltage here at around 240vac the anode =166.8v grid2 =168.2v, the anode voltage of uf89 (IF amplifier) is a bit high at 170v. Resistors have been checked and any wax caps are now gone, I’ve not replaced the big smoothing caps.
I’ve even tried to tak a 470r in parallel with the 1k ht feed resistor to try and bring grid2 voltage down, its lowered the anode voltages on the ul84 and uf89 but increased grid2 on the ul84 to 174.4v.
Any ideas please ??
Any ideas please ??
