07-02-2022, 06:07 PM
Hi.
I have a Murphy V200 on the bench. This is the 4th V200 I have attended to since 1969 which was the first one. The set was rather grubby with thick dust and grime. The LOPT is bereft of its foam covering and the smoother is wrong with only one screw holding the clamp.
Since I removed the chassis its been washed and dried and will be sitting on my toasty bench (under it has a 250W tubular heater) with the dehumidifier running to complete the drying process.
Work starts in ernest tomorrow.
Cheers.
Trevor
Trevor
