11-09-2021, 11:15 PM
This is just a general question out of interest, I think I have an idea of the question but I am often wrong.
Could a scan coil from a transistor TV be used in a valve set? I think the answer would be no as the transistor sets could supply more current to the coils and hence less turns required to deflect the beam, where as for a valve set at the higher voltages, your have less current therefore need more turns to get back to the ampere turns needed.
But there must be a point where you have to much inductance to get a good scan at say 405 or 625 line speed and I also wonder what this value could be. More turns also means higher resistance. Is there any general guidelines?
Adrian
Adrian
Learning as I go!
Youtube EF91 Valve
Youtube EF91 Valve
