22-05-2021, 11:39 PM
The used cathode changes its properties when removed from the CRT. There is little chance that it will work when the vacuum is re-created. There is also another problem. The new electron guns were delivered with a suction tube for connection to a vacuum pump as a ready set to be embedded in the neck of the picture tube. If we try to integrate a used electron gun, we have no way of connecting a vacuum pump. It would be necessary to melt the suction tube. This complicates the whole process a lot.
