02-06-2011, 10:26 AM
I finally got fed up with wobbly bits of wood with lamps, transformers and other bits strung across the bench.
This is the result, finally in one place. No great innovation, but you might be amused at the panel window that allows the lamp to be enclosed but seen clearly. Very retro and appropriate I thought.
It contains:
- isolator (100W, 240V and 115V output - enough for most sets)
- lamp (100W)
- variac (0.5A - lucky find at £5 at a BVWS do)
- switching and lamps - large orange one for mains on!
The front panel is just laser-printed film stuck on.
Over-engineered, but with my limited bench space, much neater and always to hand, so more likely to be used!
regards
Jeremy
[attachment=1824][attachment=1825]
It contains:
- lamp (100W)
regards
Jeremy
