30-01-2021, 12:53 PM
Havnt found this despite a long crawl through the Web and Farnell.
Want a board thats laid out to take IC packages with the standard 5v and 0V power tracks but can mount some sort of connector. This can be solder to board pads but needs to mate with a removable other part. Need about 20 connections.
Using those solder on screw connectors is a pain taking out all the wires for extending the circuit.
Used to use them at work back yonks
thanks Gary
thanks Gary
