20-05-2020, 03:10 PM
I bought one of these last October and have had a load of trouble with it.
I have replaced the OP MOSFETs 3 times now, I finally used some sold as Vishay supplied by Farnell.
The radio is never run at full power, it is normally at around 20 watts (at full power it goes up to 40W) and my overs are normally fairly short.
The latest fault is with USB and LSB, they are not working. But FM and AM are working fine.
If I key up on USB, without any audio drive on the mic, my PSU registers 11 amps current draw, and the radio goes into DClo alarm.
I hasten to add the PSU is capable of over 30 amps and its OP voltage is still stable at the set volts of 12.3V.
During this fault condition the radio is still drawing 11 amps so obviously I dont try this for more than a second.
I believe 3 things are happening here.
1. There is a fault causing the excessive current being drawn by the radio.
2. Either the excessive current is causing a voltage drop in the supply cable, or
3. The radios internal voltage regulator cannot cope with the current so the radio detects low voltage.
However as far as I can tell the output MOSFETs are not fed by the internal regulator so I suspect option 3 may not be the case.
My conclusion is for some unknown reason during USB & USB mode the output MOSFETs are being turned hard ON.
During AM & FM mode the MOSFETs are being controlled correctly.
I am stumped for a solution, has anyone come across this problem, could it be a software fault, or a hardware fault.
The warranties on these radios state that semiconductors are not covered so does that make the warranty null and void?
Any advice welcome.
Or if anyone has the service information for Version 6 that would be very useful.
Mike
Any advice welcome.
Mike
