18-12-2019, 11:53 AM
Over the past two or three years I have comprehensively repaired (restored) one of these 1934 'Super inductance TRF receivers, replacing all the waxed paper caps. (concealing modern replacements inside the paxolin tubes which contained the originals), including all those in the metal can!) I've also replaced several out of tolerance resistors, an incorrect rectifier valve and faulty output valve. Along the way I've checked and double checked my wiring. Currently I have a working audio amplifier, but absolutely no signals at all from any point upstream of valve L3. My suspicions fall on the switched sockets for 'pickup' or 'radio', which, in Radio mode are meant to connect the o/p of coil S14 to the control grid of L3, but does anyone else have any suggestions as to the cause of 'no reception, or a source of supply for the single pole plugs used for aerial and earth connections? All DC Voltages are OK, and, as noted above, all faulty components have been replaced.
