02-12-2019, 07:25 PM
(This post was last modified: 02-12-2019, 07:44 PM by robert the violinist.)
Hi, my cheapy multimeter stopped working so i found an old one that id packed away years ago. An Altai kd-30c. I believe i bought it in around early 1980`s.Im not too up on electronics but hoping someone could tell me whats likely to be wrong with it ?? In simple words, apart from throw in bin.
I tested it on a 9v battery for dc volts and it gave 6V DC ! But when i try and read a 8 ohm resister which i know reads 8.3 ohms on my other one which broke, but this just goes up and down in value on the digital display in a constant cycle.
Ive had a look inside . Slightly corrosion on one battery terminal but inside theres a bulb which is soldered into the circuit and it looks like it has possibly a broken filiment ,also the piece at the botton a sort of row of spiral wire doesnt look too good and a black lead on it appears to have melted a bit or something.
Any help appreciated .
Thanks Bob
Thanks Bob
