07-09-2019, 07:59 PM
Restless after the fire caused by the last GEC incendiary bomb to get back into fixing radios, top of the pile is a Philips BG400/15 AM radio. Dates from 1950 so a tad younger than me! 3 wavebands, normal rimlock B8A E40 series valve line up. This has the problematical tapped volume potentiometer, hope its usable or repairable.
I will be working off the Trader sheet mainly, number 973, as I cannot make any sense of the wave change switches on any of Philips' works sheets. The trader sheets are much better in this regard and the layout of the circuits is more what like I prefer to read.
The cabinet is bakelite, fake wood grain and paint and very scratched and dirty but seems uncracked or dinged. May clean up but otherwise it could be repainted.
Its the usual horrendously dirty set but seems fairly unmolested, obvious at first glance is the cut off mains cable, surprisingly brown and blue flex so that's not original. The back is missing which probably accounts for the builder's brick rubble inside the cabinet in front of the chassis. An odd rubber bush lying amid the aerial coil cans is not a part of the set I reckon.
All the valves are in and look whole. All the fragile clear knobs are on, but the wavechange switch is seized solid. These are the ones with through spindle grub screws, special control shafts. The detachable tuning scale is stuck fast in the slot at the top of the cabinet but the pointer moves a bit when the tuning knob is carefully turned, being extremely careful not to wreck the tuning drives, there is one for the pointer and another nightmare one for the condenser, typical of Philips of this period.
Mains voltage selector plug is in the 245v position. Nothing looks burnt, mains transformer is still tar covered. Briefly sticking some power on via the isolation and lamp limiter produced absolutely nothing, the QMB switch on the volume control sounds reasonable and the thermal switch on the mains transformer looks OK so it will have to be a chassis out to make any progress.
The outer 2 larger knobs were released once the grub screws were removed but the inner 2 small ones had totally seized screws so its dose with oil and leave it for the night.
Pictures next time, hands too filthy now to use the camera.
Sam.
Sam.
Boater Sam.
