12-07-2018, 11:53 AM
Been testing some 807's today to try and get a matched quad. Out of around 25 807's I found three faulty ones.
The first iffy one was a JAN - USA made 807 with an OC heater, it was NOS, still in the box. Tried resoldering the pins, then when that didn't work I took the base off. There was still no continuity between the htr wires. On closer inspection through a magnifying glass, I saw that one side of the htr wasn't even connected to the bonding wire, in fact the bonding wire was over to one side, not even close the htr. See pic - NC htr RHS with bonding wire about 1/4" further to the right almost touching G1 bonding wire.
The next two behaved oddly, showing way over the top Ia, 140mA + , when they should have been around 30mA. Control grid not connected maybe, no, that was ok on both. After more fiddling about and controlling Ia by reducing G2 voltage I noticed the G1 bias voltage drop to 0v if I turned up G2 voltage, so a short between G1 and G2.
However the other is a mystery, no shorts detected but the valve just runs away till the anode glowed red. Again the control grid worked ok, so maybe a G1 cathode short?
Andy.
Andy.
