12-03-2018, 09:06 PM
A regular and valued customer has brought this interesting Philips 819 line TV receiver in for repair. It doesn't need too much doing to it, at least I'm hoping it doesn't. A fellow forum member has done most of the necessary work and the faults reported are relatively minor. Sync problems for starters. These 819 line receivers don't present any real servicing problems, just think of a 405 line receiver with twice the line count. A special Aurora SCRF converter is used to supply high quality 819 line pictues from a 625 line source. The test card generated by this converter is the famous "Chevaux de Marly" pattern.
The CRT is the excellent Philips Miniwatt AW43-80, a 90* electrostatic focus tube introduced in the UK and Europe in 1957.
I think these later 819 line receivers have a reduced video bandwidth, about 7Mhz. 11.5Mhz is the ideal figure to realise the full potential of this true high definition system.
The vision IF amplifier has only two stages and uses EF80 pentodes. Earlier 819 line receivers employed four stage vision amplifiers.
Geordie McBoyne.
Geordie McBoyne.
