I bought this yesterday,
picked it up and got it home then dropped it. One hinge flew off the acrylic lid, broken away from its screw fixings, and a chunk was snapped out of the back of the lid.
I didn't notice before I bought it that the controls were labelled in German, I had decided a while ago to not buy the European ITT models, there are thousands of them, and just stick to the ones sold in the UK. Anyway at least this one is not badged Schaub Lorenz, so it almost passes as an ITT-KB model.
No thats not a USB port on the back panel it is the AM aerial and earth sockets.
Here is a better view of the sockets.
Anyway its all working now.
I fitted a new mains lead, the old one had been cut off, it had blue and black wires, blue being live. The on off switch was intermittent, so I drilled a small hole in the back so I could squirt in some switch cleaner.
I had to make a new belt for the autostop mechanism on the cassette deck. I had a belt that was almost the right fit but too sloppy so I cut 5mm out and re-joined with superglue.
The main drive belt was a flat one, it had a permanent kink in it where it had been sitting round the small drive capstan for years, if left it would have caused a bit of wow as it passed round the capstan. I managed to get it back to how it should be with boiling water to help reset the rubber and by giving it a bend in the opposite way. The heads and pinch roller were cleaned with a little meths on a kitchen tissue.
The record deck is a BSR P182,
the auto mechanism drive wheel was seized solid with dry grease. I managed to get it off with heat from the soldering iron on the spindle. The cam follower roller was also seized, the same treatment loosened that and WD40 helped to get it spinning freely, I put a drop of sewing machine oil on to help stop it seizing in future.
The auto mechanism drive wheel and its spindle was cleaned and refitted with fresh grease.
The turntable bearing was also cleaned of all the old grease, repacked and replaced.
If I manage to repair the acrylic lid I will update with some new photos.
The trouble is now, I have nowhere to put it on display.
Mike
Mike
