30-07-2017, 10:30 AM
I've been roadtesting a couple of these devices, and I'm quite impressed, a fantastic solution for the price.
http://www.sellmyretro.com/offer/details...trum-22790
Easy to use. Load your SD card with the ESXDOS operating system from your PC, and any games or utils you have obtained from WoS. Plug the unit into the Spectrum expansion port, turn on and off you go. You have the choice of using the microdrive commands to access the SD card, use the extended ESXDOS commands, or press the NMI button for a menu driven system. The Spectrum sees the SD card as a solid state hard drive, I've successfully used an 8Gb card and compared to the paltry 100k on a microdrive cartridge this is just heaven.
