21-06-2017, 03:45 PM
(This post was last modified: 21-06-2017, 03:46 PM by ppppenguin.)
I have a table where the legs are fitted by the common method of dowel screws. I discovered they were called this by a bit of googling, one end is a woodscrew, the other end is a machine screw.
Example of dowel screws:
http://www.theinsertcompany.com/wood_to_...dowels.php
One of the wingnuts is damaged (broken wing) so I'd like to replace it. Either with another wingnut or possibly better with an ordinary nut that I can tighten with a proper spanner. I suppose I'd like to replace all 4.
But what size is it? Major diamteer is just under 9.4mm and crude measurement with a steel rule suggests 16tpi. This narrows it down to M10 or 3/8" BSW according to a website I found with thread measuements. I have neither in stock
In my stores I found some plastic nuts and bolts which are probably M10 and utterly unsuitable plus one stray nut which looks old enough to be BSW. Both fit though the M10? plastic is a touch tight while the presumed 3/8" BSW is a bit loose.
Can anyone help please? Either with a way to tell what I need and/or a few nuts.
PS: The table is new-ish (less than 20 years?) which hints at metric.
In my stores I found some plastic nuts and bolts which are probably M10 and utterly unsuitable plus one stray nut which looks old enough to be BSW. Both fit though the M10? plastic is a touch tight while the presumed 3/8" BSW is a bit loose.Can anyone help please? Either with a way to tell what I need and/or a few nuts.
