13-01-2017, 04:16 PM
BRC 2000 as a baseband monitor. It is well known the BBC modified the 2000 CTV as a monitor. Reference to the IF panel circuit diagram we see that the chroma signal is picked off from the 405 video demodulator diode W2 and the 625 luma from demodulator diode W1. The 6Mhz intercarrier sound comes from W2. The circuit description informs us that both demodulator diodes remain in the secondary circuit of the IF transformer to maintain a constant load in order that the response curve is unaltered. It should be possible to introduce a CVBS input to the BRC2000 and still allow "off air" reception as well. An additional amplifier will be required to raise the 1 volt input video luma signal to the level required by the video board. The same amplifier can extract the 4.433Mhz chroma signal which can be buffered by an emitter follower and routed to the chroma board. So it follows the inputs of the luma and chroma boards can receive switched input signals either from either the baseband input or the IF panel and tuner. The audio signals will also require "off air" or baseband switching.
A viable project?
The BRC has the advantage over other dual standard colour TVs in having a fully isolated chassis.
Geordie McBoyne.
A viable project?
Geordie McBoyne.
