19-12-2016, 11:52 AM
I should clarify diagnostics is currently a weak area for me. Diagnostics is maybe the core aspect of most radio forums. Most people identify the source of a problem with test equipment and hopefully repair the set. There are other aspects, though, such as rebuilds or schematics or construction. However diagnostics is where I think I need a bit of time to get more organised.
Fortunately I try to do my research. The Saalburg 1964 GDR radio is one I shelved months ago as being too advanced. I am now taking another look to see why only FM is working. I now know the Oscillator voltage is missing from my mixer valve at the triode anode. The hexode anode is fine. I have traced accounts from others who have encountered the same problem. Breaks in the oscillator coils are the main observation. I now started cleaning this area of the circuit so I can see better as the set is very dirty. Last night I located the oscillator feed resistor which helps. Access to the piano key contact is not possible yet unless I opt to remove the PCB. I did consider the mixer valve itself may simply be defective and it's the only one where the voltage is missing. I should point out there is an FM oscillator apart and that clearly is OK. Having a schematic in German with no commentary makes this more challenging.
