10-10-2016, 09:16 PM
(This post was last modified: 10-10-2016, 09:17 PM by Geordie McBoyne.)
J. L. Baird used only two colours for his first electronic colour TV experiments. A reasonable colour TV picture can be realised by employing cyan and magenta, obviously it's not going to be as good as RGB. Found this in a Wkipedia topic about Telechrome:
Baird's comments at the time of introduction generally spoke of a two-color, 1,000-line resolution signal. This would have required considerable radio bandwidth and would be incompatible with the pre-war 405-line system introduced by EMI and the BBC. However, in the patent application he also considered the possibility of compatible color systems. One would use either frame of the existing interlaced image for each color, although this would reduce the effective resolution from 405 to 202 lines, and the frame rate from 50 to 25 fps which would increase flicker in areas of mixed color. He also mentions a system broadcasting full 405-line images, but at even greater reduction in frame rate to 12.5 fps, which is noted would cause considerable flicker.
From the ETF: http://www.earlytelevision.org/baird_ele..._color.htm
Would be a real fun project for someone with the spare time two create a two colour TV system, either mechanical or electronic.
Geordie McBoyne.
Geordie McBoyne.
