25-09-2016, 01:06 PM
(This post was last modified: 25-09-2016, 01:08 PM by Geordie McBoyne.)
The Pineapple was introduced in 1993 and I've heard of no problems with it.
A customer has brought his Pineapple in for repair. The fault is poor synchronising on certain types of picture content. Although I assembled one for my own use I've never explored the electronics. Now's the opportunity to do so.
I was about to sign off the repair of the one which is the subject of this discussion but yesterday when it's owner called in to collect the converter that old problem manifested itself again. The problem we're experiencing is black level shifts and sync pulse crushing.
For test purposes the converter is supplied with video from a DVD player, the fault is not apparent on a test pattern.
My attention was first drawn to IC U14, a 74HC4066 quad bi-directional switch. First check the black level clamp, pins 6,8 and 9. The 9uS clamp pulse is present at pin6, adjustable DC reference present at pin 9. Video sans syncs present at pin 8. Inverted mixed blanking present at pin 13. Mixed syncs present at pin 12. Fixed sync tip reference present a pin10.
A good test point to monitor the composite video is at the emitter of Q8, the video signal is correct. Move on to the final amplifier stages which consist of transistors Q9, Q10 and Q11. The fault is apparent at the emitter of Q11 and the load resistor R49.
It seems that the input stage of the modulator is causing the fault, black level shifts when the picture content changes and also sync crushing.
So now my attention when be on the RF modulator module.
Geordie McBoyne.
Geordie McBoyne.
