19-09-2016, 02:18 PM
I have found a Duracell battery with the test button on it that has strangely rotted along the test indicator.
There is a little bit of rot on the negative terminal level with the indicator strip that looks like it has spread from the mess under the strip. The rest of the battery is fine.
Has anyone else found one that has rotted in this way?
