18-09-2016, 01:22 PM
I haven't posted for a while because the hobby has had to take a back seat, but I have a project in hand and need some advice.
I have two old Pye 'Sunrise' radios which I want to partially restore and sell on to fund some other projects. The first is this Pye AC4D Twin Triple from 1930. In its day, quite a good radio by all accounts.
The cabinet on this one has suffered a bit. Both sides have splits and due to warping of the base it is literally pulling itself apart (see pics). I had hoped the base, which is affixed to the bottom of the cabinet, would come away easily. It doesn't. The glue is well bonded. Ideally, I'd get the base off, plane it flat, re-glue the finger joints and then re-affix it. However, I am worried I will do more damage trying to get the base off, than just leaving well alone.
If the base is stuck with hide glue I was wondering if applying heat from inside the cabinet through the thinner cabinet bottom panel might sufficiently loosen the glue so I can prise the base off?
Has anyone here encountered and tackled such a problem before?
Thanks
Nick
Thanks
Nick
