Hi
After having finished servicing the last 6 Hacker radios, I am now embarking on a few more Hacker radios belonging to my friend. This time there are 3 Sovereign III's in the batch, and a couple more Sovereign II's
The first radio, a RP72, needed a lot of work to get the switches to work reliably, but after a while I discovered the main cause of the problems with switching to LW was a weak joint on the LW aerial trimmer which had broken and was intermittent.
I have done a RF realignment of all bands so as to get Gold in on MW and Classic FM on FM and R4 aligned with its mark on LW.
Something strange is happening though, and I wonder if anyone else has had this on their a RP72. If you tune to LW R4 and then switch to MW there is a fainter R4 signal at exactly the same spot on the dial. Both LW and MW are working very well in their own right, I can receive the Irish RTE station on LW and I can also get Gold on MW which is also fairly difficult around here on a portable radio.
This RP72 radio does not have a built in mains power supply, but it does have an oval hole in the back where a mains plug would fit. I notice both the other radios, which have a mains supply are RP72MB's.
Was the RP72 never supplied with a mains adaptor?
Thanks
Mike
Thanks
Mike
