22-07-2015, 01:34 PM
Photo of some the bits that will go into the new Freeview rack at the Vintage Wireless Museum. The one I built a while ago is a bit of an abortion so time for a better job. The skilled wood and metalworkers here at GVR will likely be appalled but unless somebody is volunteering it's yours truly doing the work.
The idea is to stack 3x Freeview boxes to give BBC1, ITV and BBC2 all available simultaneously. Freeview boxes aren't entirely reliable so it will be easy enough to pull one out and replace it. The sizing (2" high gap between shelves) and full rack width is ample to take just about any box we're likely to find. A Poundland 3 way mains block will be hooked up to the IEC inlet. Each box will have a pair of Scarts feeding dual audio/video Phonos/BNCs on the back panel. The aerial inlet is an F barrel from which a co-ax will be looped to each box.
At the moment the shelves will be offcuts of laminate floor supported on bits of 2"x1" batten. The whole thing needs to come in at under 7" high, or 4 rack units. Since the boxes run quite warm the 2" gaps should give adequate ventilation.
If anyone can think of a better method of doing the shelves that's easy for a wood/metal bodger like me then please say.
