13-05-2015, 07:52 AM
(This post was last modified: 13-05-2015, 07:56 AM by Old Sparky.)
I have recently replaced a couple of capacitors (C4 & C6, both 5n6) and R4 (220k) in one of the above, as all were out of tolerance. The player is now working, but should I, on safety grounds, replace the isolating capacitors (C7, C9, C11, & C12), all of which are 4700pf red ceramic disc types, the first 3 isolate the pickup from chassis, the last is a 'spark suppressor' fitted across the motor on/off switch, with modern class 'X' (or should that be class 'Y') types? N.B. This model was fitted with a 3-core mains lead from new by Philips. This is shown in the circuit diagram.
