04-03-2015, 05:14 PM
Hello to all,
I'll try and briefly share details of my car cassette project. It's a seventies car cassette player that wasn't working at all. Over time I found out the negative supply lead was out of circuit on the input side. I found that through by-passing that and feeding negative supply upstream, it powered up. However, after it turned out both drive belts had had it.
I finally got this player to play a cassette although it wasn't easy. I had to lock the cassette into place manually and cleaning the heads was very necessary as the whole machine was pretty dirty. I bought one proper drive belt and used an O ring for the other one (that wasn't the best idea).
The reason I'm posting is I've never been sure of the belt layout. At present the play setting works but on fast forward so far, tape can spiral out as the take-up reel isn't doing its job at this time.
Is there any way to know if I have these belts correctly fitted? Unfortunately the workshop manual is a bit vague and shows no complete diagram of the belt and its pulleys.
Good news is I ordered more belts and am glad it does now actually play. The mechanism is still not functioning that well but I hope to sort it all out in time.
