03-10-2014, 12:11 AM
I bought this about 30 years ago cheap and found parts to make a much better one weeks later.
The volt meter is missing its cover and is also open circuit this fault being in the moving coil itself.
I have a replacement that reads the other way round so another scale will have to be made so that it can be mounted with the coil at the top.
It is crude and will and there is a burn on the PCB close to the rectifier.
Currant limit is by a heavy pot that shorts out the currant limit pins on the 723 regulator when set to maximum and it only works from 1 amp to 2 amps and the meter only goes up to 1 amp so it is not a lot of good really as it is.
The mains transformer has been bodged a bit too but I have no idea why it was done.
The good thing it that it has circuit breakers both sides of the transformer.
