28-03-2014, 09:21 AM
Whilst working on the above 20 year old midi HiFi, I found that, when I switched it on, having taken the metal oter cover of, none of the functions worked and the display was only partially visible. I had a jumper lead connected between the metal rear panel & the front metalwork (the cassette mech. chassis) although i couldn't see that any of the electronics used that as a ground. Checking with a multimeter, all points marked 'ground' were still earthed to the rear panel even without the earth jumper in place. Oh H*** I thought 'microprocessor failure' Anyway, I put the cover back on, switched the set on, and, to my relief, everything worked. The only odd thing no is that if 'Aux' is selected a flashing 'E' appears in the display, as it does if the unit is switched to standby. If the Deck 1/2 button is pressed 'ERROR' appears, but there is a mechanical fault in deck 1 anyway.
I've never had the above happen with any other modern processor controlled system. although I have had a few uP failures, despite wearing an earth strap and using an anti-static mat, so what was happening there?
To cap it all the reason I openend it in the first place was to service the CD Player.
Phoned CHS only to be told that the Laser PU is NLA!
