07-03-2014, 09:06 PM
Had this by email
Any thoughts chaps.
Quote:Here is the schematics mark. It is a power supply for a galanti duovox amp/tone generator combination. There are only 6 or so items in the circuit. The 100 watt amp was dead when I got it. The resistor circled had blown no markings on it. I replaced the b80c bridge rectifier as it showed defective The caps and other resistor show good readings.The physical size of the cap in the 40 volt side with the blown resistor is 75mm x 45mm this is just to give you an idea of the actual dimensions. Any help would be much appreciated thank you richie
Any thoughts chaps.
Keep on Fiddling!
