21-01-2014, 10:51 PM
I'm having great difficulty removing the two screws along the RH side of the motor board in one of the above, which had beedn stored in damp conditions for many years, I'm told. My feeling is that corrosion has 'welded' the screws to the spire nuts.
I cannot turn them with eiter a conventional screwdriver or one of those bits designed for removing seized screw, neither can I drill off the heads. The bottom of the cabinet isn't removable, so there's no wat to get at the underside of the motor board. Unless I can get the motor board out, which is neccesay in order to gain access to the lower two nuts securing the amplifier/speaker assembly to the cabinet, then the player is scrap, which is a pity as it works after a fashion, but needs the usual electronic & mechanical overhaul. Does anyone have a solution to this problem. Plus Gas, btw, will not loosen the screws, presumably because it isn't penetrating far enough down the screws.
