10-10-2013, 08:11 AM
Does anyone know the proper way to do this? A secondary question is; Should the pickup head be over 30 degrees above the horizontal plane when the arm lifts off the rest in 'auto' mode?
For those who aren't familiar with this BSR deck, the BDS95 (AKA P163) has a calibrated knob at the RH side of the Gimbal (as viewed from the front), an uncalibrated counterweight which is adjusted by means of a screw in the rear end of the P.U. arm, and the usual anti-skate adjustment.
Nothing appears out of place or damaged on this deck, btw.
