02-10-2012, 08:37 PM
OK, this is likely to be a long time until it gets completed. This is the donor Groom I got to finish off the other set. I decided that, since this set is very badly bodged already, I would strip this one down to bare metal and completely rebuild it. Along the way I'll see about a replacement dial and any other items that will need replacing.
Since a previous 'repair' involved replacing the rectifier valve with a mains transformer and silicon rectifier, it also involved replacing the audio output valve (25Z6) with a 6V6G to get round the heater voltage problem.
I've managed to get the front panel off without causing the dial cord to come undone so that's a good start! I'll be removing it anyway but not before I figure out how it is supposed to be run - and document it, etc.
So, I'm going to use this project to learn as much as I can along the way and hopefully I'll get it all back together to its original spec at some point in the future.
Cheers, John
Cheers, John
