15-03-2012, 02:25 PM
This is my latest auction purchase:-
It worked as was but I gave the movement a partial clean as I wanted to take it out while I did the case up. The suspension spring has previously been bodged up but it didn't seem to effect its operation.
All this involved was taking the escapement off and allowing it to run down in kerosene, I don't have access to petrol, and after it had dried re-oiling it.
I had intended to strip and French polish the case but after getting it thought it was in good enough condition to salvage.
I looked much better after just a coat of linseed oil rubbed in with a pan scrubber.
The only woodwork needed was repairing some loose veneer on the base which was in danger of snagging on the duster while polishing it. Due to the shape clamping it would be challenging to put it mildly. It also seemed too springy to secure with tape.
I tried putting the iron on it in the hope it would re-stick with the original glue but it didn't, maybe it had previously been repaired with PVA or the like. I therefore cut some paper-thin slivers from a hot-melt glue stick and put them between the veneer and wood and clapped the iron on top and this worked very well indeed.
After that the case came up very nicely with a couple of coats of wax.
I didn't want to end up with a toffee apple and as there are marks on the face, about which I can do nothing, making the rest look too good would make these stand out all the more.
I'm certainly happy with the result.
It's now soaking and will no doubt need regulating. The striking sounds very nice too.
- Joe
- Joe
